New Walnut Uke http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=26517 |
Author: | Quine [ Sat Mar 13, 2010 5:31 pm ] |
Post subject: | New Walnut Uke |
Here's my latest build....a walnut concert ukulele. Based off the Martin style plans from Elderly All walnut body, mahogany neck, wipe-on poly finish. It sounds really sweet so far!! Has anyone used wipe-on poly on rosewood? The finish went on great except for the rosewood veneer. It didn't seem to cure well, even after a few days. It wasn't sticky, but soft and easy to fingerprint. I ended up scraping it off and using shellac on the headstock. |
Author: | jackwilliams [ Sat Mar 13, 2010 5:38 pm ] |
Post subject: | Re: New Walnut Uke |
Nice looking uke ; I really like the rope styled purfling, jack |
Author: | Joe Sustaire [ Sat Mar 13, 2010 6:02 pm ] |
Very fine uke! ![]() And rope on ukes just seems perfect. Walnut is a nice change from mahogany. You say you got the plans at Elderly? Joe |
Author: | Bobc [ Sat Mar 13, 2010 7:20 pm ] |
I like it a lot. Very nice work. |
Author: | cphanna [ Sat Mar 13, 2010 8:14 pm ] |
Much prettier than the walnut uke I've got in the works at the moment! |
Author: | unkabob [ Sat Mar 13, 2010 8:43 pm ] |
Quine: Nice job! How is the action? The saddle looks a tad high but if the action is right , its right. Bob |
Author: | MRS [ Sat Mar 13, 2010 8:45 pm ] |
Wow! Make me want to build a uke now...mike |
Author: | Quine [ Mon Mar 15, 2010 12:41 pm ] |
unkabob wrote: Quine: Nice job! How is the action? The saddle looks a tad high but if the action is right , its right. Bob Thanks Unkabob. The action is a bit high now. I plan to drop it some and do the final adjustments to the saddle. I also have to shorten the strings some....almost ran out of tuner capstain. Man these nylon strings can stretch!! I just got to the point where I wanted to string it and play it for a while!! ![]() |
Author: | unkabob [ Mon Mar 15, 2010 1:39 pm ] |
Quine: That rope purfling is to die for. A truly fine piece of work. Bob |
Author: | Tom Dowey [ Mon Mar 15, 2010 1:55 pm ] |
Very nice looking uke. I am always curious on how the neck is attached on uke's? How do you attach yours? Thanks in advance. |
Author: | Philip Perdue [ Mon Mar 15, 2010 2:08 pm ] |
Quine, This is a very nice looking ukulele. I really like the rope binding and purfling. Did you make the rope? If not where did you get it looks perfect on the ukulele. Yes, it does look like pretty high action. Great Job! ![]() Philip |
Author: | Pat Hawley [ Mon Mar 15, 2010 2:29 pm ] |
Nice looking uke. As you mentioned, polyurethane doesn't dry too well over rosewood. I found that it helps to do a couple of coats of shellac prior to the urethane. Pat |
Author: | Quine [ Tue Mar 16, 2010 12:32 pm ] |
Thanks Philip. I didn't make the rope this time. I got it from LMI Tom...I used a mortise/tennon joint for the neck. I figured the hole was too small for a bolt on |
Author: | Darrin D Oilar [ Tue Mar 16, 2010 3:29 pm ] |
Just got back from Hawaii yesterday and was thinking I need to build an Ukelele. Saw some nice ones in a store in the Sheraton. This one and hearing Bruddah Iz for the last several days just reinforces it. Beautiful Uke. Darrin |
Author: | Rob Warren [ Tue Mar 16, 2010 5:11 pm ] |
Great looking Uke. I've just started a Koa Baritone Uke for my uncle. |
Author: | PhilL [ Tue Mar 16, 2010 5:53 pm ] |
Joe Sustaire wrote: Very fine uke! ![]() And rope on ukes just seems perfect. Walnut is a nice change from mahogany. You say you got the plans at Elderly? Joe I'd also be interested to know how you liked the plans. I'm finishing a second guitar right now through the Colorado School of Lutherie (http://www.evd303.com/school.php) with Edward Dick. I was thinking that a concert Uke would be a great project to try on my own. I've been looking around for a plan to start with. Phil |
Author: | Philip Perdue [ Tue Mar 16, 2010 7:17 pm ] |
Quine, I think I will use your ukulele as an example for a future build. The look is classic and stylish. I also wanted to let you know about the current Luthier sale going on at Hibdon Hardwoods. They have Mahogany sets and wood for necks that have some issues but are really inexpensive. It is likely that the ukulele template will clear the wood better than a guitar template. Since you and Hibdon are in the same town I would think you can pick the woods yourself. Also, on the next ukulele build you might try a pass through pinless bridge instead of the tie bridge. This is very popular in the ukulele community. Check out this thread that has photos from Dave White. It really makes a clean looking intrument. http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=22416&p=308356&hilit=bridge#p308356 PhilL, If you are checking out plans you might try the following two locations. Hana Lima ‘Ia has a variety of plans including Kasha braced plans. Another site to try is Bob Gleason’s Pegasus Guitars and Ukulele. http://www.hanalima.com/ http://www.pegasusguitars.com/ Philip |
Author: | Quine [ Wed Mar 17, 2010 12:39 pm ] |
Hey Phil Here's a link to the plans.... http://elderly.com/books/items/113-45.htm Its a good set of blueprints with a few options on construction....even a pineapple body shape. I used the standard 2 tonebar style. |
